Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
HFSS/HFSS-IE Antenna Reflector Gain/Efficiency accounting
    • hxb160030
      Hello Ansys representative,
      • I am using the near field solutions of a 300GHz patch array designed in the 65-nm CMOS process and exciting a cassegrain reflector structure in HFSS IE. I get the gain, directivity and efficiency numbers (listed in the slide attached) from —
        • A single element excitation (say element 1, 2 , 3 … etc)
        • 7 individual elements (active array not connected — neither in series nor in parallel) excited at the same time
        • And after the 7 element array’s near field solution data is fed to the reflector in HFSS IE.
      • Could you please help me understand — does the reflector’s antenna parameters (obtained from HFSS IE) include the array’s efficiency effects? Considering gain vs directivity — is the efficiency counted twice - once in HFSS for array simulation and second in HFSS-IE for reflector simulation?
      • If we are going to use gain, we have to use the power delivered to the antenna not the total radiated power from the circuit?
      Thanks and Regards,
      Harshpreet
Viewing 0 reply threads
