October 23, 2018 at 5:12 pm
mahmoud
SubscriberHi,
I am trying to simulate an FSS on a dielectric reflector (both of them mimic a radome) and use Hybrid HFSS setup. What I did is to assign both the FSS surface and the dielectric reflector as a IE region. Then enclose them in a FEBI open box.
I tried to simulate, but I get this error below, which I do not know how to overcome it. Also, the way I drew the FSS on top of the dielectric reflector is to imprint it.
Any help is appreciated.
Thanks,
Mahmoud
October 23, 2018 at 5:13 pm
mahmoud
SubscriberOne more note: the FSS is a sheet and the reflector has a thickness
- Maxwell, HFSS or Q3D?
- Error
2630
2104
1329
1110
461
