March 8, 2022 at 9:10 pm
naftali.herscovici
SubscriberHello,
I am looking to get the information of all HFSS instances running at a certain time
All I could find in the manual is this command for VBA
set obj = oRunningInstances.GetAllRunningInstances()
Assuming there are two instances running I would like to get the following information. Something like
for i=0 to 1
debug.print obj(i).Name
debug.print obj(i).Path
debug.print obj(i).Projects()
debug.print obj(i). Designs()
next i
The code above does not work. Not sure how to do it
Thanks
March 21, 2022 at 2:26 pmPraneeth
I see that you are using debug .print command.
May I know from where you got to know about this command?
Are you using the correct syntax for it?
Please check once.
All the very best Praneeth.
- Maxwell, HFSS or Q3D?
- Error
2610
2088
1321
1108
459
