October 26, 2018 at 8:50 pm
Osama10
SubscriberHi,
After renewing the license, ANSYS HFSS is not working anymore!! IT gives me the following error:
Failed to check out license 'hfss_desktop' license server machine is down or not responding (FLEXlm Error -96)
In addition, ANSYS license management center shows "The required license file was not found in: C:Program FilesANSYS IncShared FilesLicensinglicense_files" after pressing start as in the attached photo.
Please help with this issue.
Thank you,
Osama
October 26, 2018 at 9:39 pm
tsiriaks
Ansys EmployeeHi Osama10,
Please post the screenshots of the following info
- open CMD Prompt then issue the command 'hostname' without quote ' '
- open the new license file that you received and take the screenshot of those lines before the INCREMENT lines.
Thank you,
Win
October 26, 2018 at 9:53 pm
October 26, 2018 at 10:05 pm
tsiriaks
Ansys EmployeeHi Osama,
Thanks for the screenshots.
So, your machine is pointing to the license server ECCANSYSLM.
Have you verified with the server admin that they have installed this new license file on the license server machine ?
If it's up and running on the license server, I think the ansyslmd port might have changed. Please make sure your machine can communicate with the license server via that port. By default, the ansyslmd process is run on dynamics port (change every time you restart the process) but your server admin can do the following steps to specify it to run on static (fixed) port
To set the ansyslmd port to be static , please go to this (default location)
(Windows) C:Program FilesANSYS IncShared FilesLicensinglicense_files
(Linux) ../ansys_inc/shared_files/licensing/license_files
, and modify the VENDOR line in every .lic files
so that it looks like this
VENDOR ansyslmd PORT=1056
(of course, you can use other port aside from 1056 as well)
Thank you,
Win
October 26, 2018 at 10:40 pm
Osama10
SubscriberHi Win,
Yes, they installed the new license as they did every year. We face this problem for the first time!
But when I went to the location I didn't find any .lic files!!
When I pressed on "add a license file" on the ANSYS license management center webpage, it gives me "2018/10/26 18
6:59: Did not upload file - Error: The hostid in the license file is not a valid hostid for this license server machine."
So what should I do in this case?
Thank you for your help,
October 26, 2018 at 11:18 pm
tsiriaks
I'm guessing you are opening this ANSYS License Management Center from your own machine. You don't need to (and can't) install this license file on your local machine. You are already pointing to the license server to use the license from there. So, nothing needs to be done on your side (local machine) now. You can just pass along my message in previous post to your server admin/IT and they will know what to do.
Thanks,
Win
October 26, 2018 at 11:31 pm
Osama10
SubscriberThank you Win,
I will forward it to them and will inform you on Monday if the problem solved or not.
October 27, 2018 at 12:14 am
tsiriaks
Ansys EmployeeSounds good.
Thanks,
Win
October 31, 2018 at 3:19 pm
Osama10
SubscriberHi Win,
They did what you suggested but, unfortunately, HFSS is still not working!
They told me we have version 14 of HFSS and the license is for version 18. Is this could be the reason causing the problem?
If yes, could you please provide me with a link to download ANSYS EM v. 18? I searched on your website but I didn't find a link to download the software.
Thank you,
Osama
October 31, 2018 at 6:01 pm
tsiriaks
It depends on what license feature name that your license server has.
The AnsysEM (HFSS) v15.0 or older will be calling only for hfss_desktop license. This has become a legacy license , so if the license file is recently generated for your license server, it will not contain this license feature name, it will instead have electronics_desktop license feature. This electronics_desktop license is applicable for v16.2 or newer.
You can find the download by logging into ANSYS Customer Portal -> Downloads -> Current Release -> here you can select the installation packages for releases as old as 17.0
Thank you,
Win
October 31, 2018 at 8:08 pm
Osama10
SubscriberHi Win,
Unfortunately, it is still not working! They tried to install v19.2 but also it is not reading the license!
They told me to check from you if the license we have is for ANSYS HFSS software, so how can we check this?
Could you please tell me our license is for which software and what version we should use?
Thank you,
Osama
October 31, 2018 at 8:59 pm
tsiriaks
Can you post the entire content of the license file that you or your colleague receives from ANSYS Account Manager ?
Also, can you post the screenshot of the current issue ? Is ANSYS License Manager running but you can't run the software, or ANSYS License Manager is not running ?
Thanks,
Win
October 31, 2018 at 9:09 pm
Osama10
SubscriberHi Win,
Please see below the content of the license file we received "license-ansys_hybrid_10012018_094020_462_AM":
ANSYS License Manager is running but it shows the license is stopped. The software is not running and it shows the error in this screenshot.
SERVER ECCANSYSLM 00155db7740c 1055
VENDOR ansyslmd
USE_SERVER
# Products licensed in this file:
# 1. ANSYS Academic Teaching Mechanical and CFD (50 tasks): 1 task(s) Lease expiring 30-Jul-2019 Customer # 1000533
# 2. ANSYS Academic Research HF (5 tasks): 1 task(s) Lease expiring 31-Aug-2019 Customer # 603925
INCREMENT aa_ds ansyslmd 9999.9999 30-jul-2019 50 28893E948FDC
VENDOR_STRING=customer:01000533 SUPERSEDE ISSUER=SIEBEL
ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="0092 219F 1281
5C3E 82A0 3877 61CD DB00 A07E AD96 1E56 DCE8 2C80 D2DA C8D6"
INCREMENT aa_mcad ansyslmd 9999.9999 30-jul-2019 50 01FAAE77E191
ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="00A9 4436 6F04
D996 5401 E136 8153 7800 BBAE 9729 B0C7 AF58 0850 EAB8 13E3"
INCREMENT aa_t_a ansyslmd 9999.9999 30-jul-2019 50 70AD24689DC4
ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="0040 4A02 091A
B65F DA37 7210 CB52 F900 2E65 D490 C0B5 A954 266A FF2F 462F"
INCREMENT afsp_gui ansyslmd 9999.9999 30-jul-2019 50 13DC6D2F3D08
ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="009C 1FA7 759A
1BB3 AD43 9152 27A2 9900 E503 4E65 891C 202B 1363 CF4B A20D"
INCREMENT afsp_optigrid ansyslmd 9999.9999 30-jul-2019 50
65B8E766709D VENDOR_STRING=customer:01000533 SUPERSEDE
ISSUER=SIEBEL ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="0097
6517 FC2D 6FC5 48B5 E3DF 789A 8700 54DF DB00 BBA7 B872 9A94
27A0 6C19"
INCREMENT afsp_viewmerical ansyslmd 9999.9999 30-jul-2019 50
FC0F7D6F3BDA VENDOR_STRING=customer:01000533 SUPERSEDE
ISSUER=SIEBEL ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="003E
C169 76BA A71B 989B 2AB4 BDA0 FF00 62ED 5ABB FCD0 8DE9 4C4D
2C40 B5F7"
INCREMENT aim_mp1 ansyslmd 9999.9999 30-jul-2019 50 08D9AE9CA612
ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="00ED E722 E8F2
BFE5 9B14 5734 6495 4600 1E09 224E B19A 7139 0EEC B10F 02B8"
INCREMENT a_spaceclaim_catv5 ansyslmd 9999.9999 31-aug-2019 5
VENDOR_STRING=customer:00603925 SUPERSEDE ISSUER=SIEBEL
ISSUED=01-oct-2018 START=01-oct-2018 AUTH={ ansyslmd=(
LK=55A647DB9DFF SIGN2="0079 4CC9 649A B9D7 0D5D DF08 4EB2 1C00
065B E824 9728 2CAE 15F1 E60E B3AD") ansoftd=( SIGN="00F4 45F1
1F42 657F 8DDD 5435 B364 A500 2AE1 6C3C C3FF 22C5 75A9 8E1F
0E76" SIGN2="0023 61D0 5881 3442 8CE7 0EB7 8B8C 3300 BAD2 BB14
D6BF 9DEE 833F D665 5C96") }
INCREMENT a_spaceclaim_dirmod ansyslmd 9999.9999 31-aug-2019 5
LK=DD656F6E1253 SIGN2="0040 E3FD 72F5 C7C7 A9F8 7318 C864 9100
B33D F54A C30B FA6D 90D9 2204 C861") ansoftd=( SIGN="0013 0D7F
FFD0 26EB 6EC9 F602 8F3A 0700 A3B6 9A24 958A C673 20A7 EDB7
4C3D" SIGN2="0021 869D 7377 B137 C770 3E0C 87F0 9200 29CE 7198
3380 BB35 2081 C510 8796") }
INCREMENT aice_mesher ansyslmd 9999.9999 31-aug-2019 5 6AC94CFE71BA
ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="0053 F273 45E6
178E 068F 19DC 9418 F900 31E3 E3EE 894F 8625 4A1B 6A1D A8A9"
INCREMENT aice_opt ansyslmd 9999.9999 31-aug-2019 5 8529980D3878
ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="003F 3FA3 C53E
3F0E D276 0192 7201 2300 9276 1DEF 9565 079F 7B0F 9C4D D5A5"
INCREMENT aice_pak ansyslmd 9999.9999 31-aug-2019 5 4397F67C852A
ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="00C7 09BB 84A4
A815 CA16 00B0 CA3A 2800 3936 1F34 CEF0 6876 D058 698F 1367"
INCREMENT aice_solv ansyslmd 9999.9999 31-aug-2019 5
LK=EEBDDE142006 SIGN2="00A6 9925 629D DE6C 409E 27F8 B391 8F00
C43D CDB9 6206 1F56 A96B 2D21 DE7B") ansoftd=( SIGN="0053 B0D0
5D7F 2C06 2B3D 75EA 7390 3D00 FAA5 36FD 1D14 EC87 6A94 3F85
BAC1" SIGN2="0030 4567 BCAB FE1F 0761 B5E3 DCE5 3100 E138 2924
FA7F 7538 CFDB 8AE6 453A") }
INCREMENT aiiges ansyslmd 9999.9999 31-aug-2019 5 C63DF47E59F6
ISSUED=01-oct-2018 START=01-oct-2018 SIGN2="0086 375E 1EC7
806F D938 F58C 5071 BD00 DCA0 C558 AB5B 6890 AC9E 8650 7D18"
INCREMENT al4allegro ansyslmd 9999.9999 31-aug-2019 5
LK=8738E7193817 SIGN2="0026 3129 30F9 4B10 41F0 6FA9 5636 4C00
A6AA 20C2 5372 2D3D 1F37 FBA1 3602") ansoftd=( SIGN="00FB 8D24
7AC7 07E4 F403 C8CE 0F3D 3F00 E381 09BC AE6B 1962 C065 9D87
B181" SIGN2="0063 4DFC DC54 B600 9154 BC14 505B E800 7D11 0FCA
9A1C 1905 B407 287B B985") }
INCREMENT al4ansoft ansyslmd 9999.9999 31-aug-2019 5
LK=D04A4B78A2D9 SIGN2="0087 595D 6276 4928 5A6B 59DF 7591 8D00
4F0C 06B8 D5F2 7CC7 1EE0 7B23 6D47") ansoftd=( SIGN="000D 5B45
B222 79BB 1623 C4FC 48C9 8000 81D0 3890 86AD 1CC5 D25D 9755
C5E7" SIGN2="0033 4F24 8437 AF0C EBF4 0795 5B34 C100 7E14 5B1D
5CF6 2394 7323 E172 5067") }
INCREMENT al4apd ansyslmd 9999.9999 31-aug-2019 5
LK=4DAA3C953578 SIGN2="004B 07EC 24A7 9CD7 57D4 836D 45CA 8500
7B57 2980 FD68 9C75 1AE5 18E9 F5F3") ansoftd=( SIGN="0069 2335
131C 9941 FB7F B233 CBEF EA00 4376 D2F0 E2A1 02ED F860 8B33
35F2" SIGN2="005B 95B8 3796 1D88 6732 5433 4F39 7300 D464 34C1
18DC 4FD6 E349 1C5C 3A5D") }
INCREMENT al4boardstation ansyslmd 9999.9999 31-aug-2019 5
LK=9C0F9606FFD7 SIGN2="0075 ED13 8603 E541 605B DDFC F8E6 9F00
8BA6 9BD3 222F A71A 408C 17BE AF00") ansoftd=( SIGN="003D A6A2
DA00 1A95 7C86 ED00 4D64 DF00 A210 B537 4464 1B12 86DC A669
ABB2" SIGN2="0064 8DB1 C2DA A106 3995 9CF7 86A3 7700 1865 437C
8FE2 3B07 DDB9 5EB6 C677") }
INCREMENT al4cadvance ansyslmd 9999.9999 31-aug-2019 5
LK=BB21031B5703 SIGN2="003D 037E 160A 6399 EDBD 2879 9720 2400
2A6E 7F22 A852 2C65 BFFE 7CF6 1D89") ansoftd=( SIGN="0030 BF2F
246F 72C3 F09B 2549 0DDE EB00 810D 2DCB F67E 7473 2463 11EC
D531" SIGN2="003A C931 97C5 509F 6CC1 212A 8DD0 0400 32AC 8CBF
90FE D8ED F1A2 B0D6 4C1F") }
INCREMENT al4cds ansyslmd 9999.9999 31-aug-2019 5
LK=A85F0BE310E2 SIGN2="00F4 5661 CCE7 B066 7666 05B0 9CB8 0300
5F8C ACC0 8165 65E2 F6C5 6262 0AAF") ansoftd=( SIGN="006B EF0B
21B4 A918 D565 1769 AF1E 4900 6CD0 B432 C387 6942 0A70 8157
47C0" SIGN2="00DC 4873 D9D0 F5DC CD66 60FA 131A 3A00 3975 E997
C605 3DD6 25B1 18FD 82EF") }
INCREMENT al4expedition ansyslmd 9999.9999 31-aug-2019 5
LK=A201EC8432A4 SIGN2="0006 F3BE 3B6B 9845 2870 7371 EDB9 6E00
F833 3397 68A5 4B36 5415 A105 16E9") ansoftd=( SIGN="0042 7755
B472 7E9E 35CD CB7F 5A58 FA00 EA74 9DCD 0A0B D826 BBBE 4AE9
4F64" SIGN2="008C BDC0 99CD 6459 7AA3 BF26 76AC 3B00 D0A2 0D74
B38A B0A5 E122 D1C0 69FE") }
INCREMENT al4first ansyslmd 9999.9999 31-aug-2019 5
LK=ADF1E9834CCF SIGN2="009E B1B4 6DE6 D56C 8977 C3C7 2F43 9200
D846 9293 FFE6 4D1D AF40 A94E 9A73") ansoftd=( SIGN="003C 176F
FEE7 1B86 7AAC D4CA BEFC 8700 5AD6 3BBE 882C DDD8 F288 D3B7
162C" SIGN2="00BF 77C4 C49E 6C51 0265 A923 F398 CE00 1897 75B1
AAA9 FC10 3469 12E1 2834") }
INCREMENT al4gem ansyslmd 9999.9999 31-aug-2019 5
LK=5B31B69492BC SIGN2="003D 28C7 789D 40AF 5A20 C992 D809 DA00
3066 9DAD FF36 1313 9992 90A6 FD63") ansoftd=( SIGN="0047 EEC2
9723 4A79 78E5 A9D2 C211 8800 C09D 4AE8 CBD0 01A6 B66C E424
A1AC" SIGN2="0071 FD07 384D 0AF7 A0CC F539 8EB2 0500 6B8C C51E
23A4 DCA4 5E04 63C3 DF7C") }
INCREMENT al4generic ansyslmd 9999.9999 31-aug-2019 5
LK=14B94817618B SIGN2="0001 21F2 95A0 60A4 9483 4D71 DB17 5100
6429 62AD BB14 C9EA 12B1 5DCC 82E6") ansoftd=( SIGN="0062 AC5D
E418 ED9F 52F1 A0BF 356E 7500 13A2 A44A F4FE 4201 E82F 587B
1970" SIGN2="00CF 2CC0 5736 1F37 1E83 8D3D 519A 9900 4160 2B17
CAC5 7A17 8352 DEC3 DD12") }
INCREMENT al4odb++ ansyslmd 9999.9999 31-aug-2019 5
LK=0ED1719C856C SIGN2="00F1 E01A 3809 F29D 625A 1AF2 68AD 9C00
7737 B3A6 224F 89DF 06ED 2B22 D68A") ansoftd=( SIGN="0042 0458
8A74 07D3 2D5F E9A1 ABEF 7800 2E4B 47D7 C33C 18BF A2B7 1EB1
283B" SIGN2="0001 AE15 64A5 2F04 5C44 7E74 0F6E 5E00 5368 589F
7714 8430 72E2 E5F5 1D67") }
INCREMENT al4powerpcb ansyslmd 9999.9999 31-aug-2019 5
LK=C392A7BD70E1 SIGN2="00CE 0E50 B2A0 525E 815F FEB2 19F5 E700
CB20 D4C6 CF2B 0AEE 609F 5BD3 F1DE") ansoftd=( SIGN="0087 9D8A
9BE7 C10C D219 6EC3 9098 9100 A08A 1693 5946 0788 5B62 BB11
8ED2" SIGN2="00AC B448 792E 536A CB9F 89B2 52EA F800 66B5 122B
F009 3BA4 6B2F B7BF 66F2") }
INCREMENT al4virtuoso ansyslmd 9999.9999 31-aug-2019 5
LK=6B055C44CD89 SIGN2="003D E771 5A7C 64F3 848D 175B 9797 C200
EAE5 30DC E96D 72C8 02B9 E9E1 C3A1") ansoftd=( SIGN="0027 E4D1
E39A D4E8 405E 4D5B 1BCF FD00 C09F 54CE EE20 AE23 11E3 8354
1164" SIGN2="000D 83C9 09B6 AE36 8839 BA72 E6EE 9600 5140 035B
4DB9 4E38 BD5E 8954 12A5") }
INCREMENT al4zuken ansyslmd 9999.9999 31-aug-2019 5
LK=7F5AF4C13417 SIGN2="00D7 1DAE 6E9F 5BDE FE73 9636 FDBC 5B00
69F6 3632 ED00 272F BE99 36AA 0135") ansoftd=( SIGN="0032 483D
FB19 22FE 0873 D938 BEE3 4800 EC35 453A 47BC 60C0 7EAD B8E3
6C1C" SIGN2="0027 6FFB CDE4 932A 4144 D402 B153 7700 944C 2B36
F2E8 0C3F B19E DD15 2779") }
INCREMENT ansoft_distrib_engine ansyslmd 9999.9999 31-aug-2019 40
LK=1FB253F536DD SIGN2="0050 F3F9 18D2 59B5 B7BC D0F8 A769 8200
4D93 5A5B 1211 8152 BF23 C6AF 9460") ansoftd=( SIGN="00B2 FC76
9023 E2E2 9823 63C7 6270 A800 DE5B DED9 26AF 83FC E2D3 53C6
C0F9" SIGN2="001E E76D CE2E 2B7B A5E5 BB1D F656 5D00 ECE2 B620
71F8 0644 59F0 A83C 052B") }
INCREMENT designer_hspice ansyslmd 9999.9999 31-aug-2019 5
LK=19A324B97568 SIGN2="00D6 137E 1612 21D2 609F E1C9 A249 C700
F64E 44AA 877D 0A95 E18A 1211 D46B") ansoftd=( SIGN="00B0 59A8
2BE9 CA28 241F B955 C687 9200 CA16 6521 C989 BAD0 734B 9838
0C5B" SIGN2="00BA 1FE4 68C7 1AB5 1C25 0834 FD96 D900 D678 71CD
CFB5 EE43 0E25 B527 8401") }
INCREMENT electronics_desktop ansyslmd 9999.9999 31-aug-2019 5
LK=A1EBD96A0054 SIGN2="00FA F892 32C1 E292 FDC8 A1F4 AC49 2C00
F11F 45E1 30BF 011C 545B 601A F3C5") ansoftd=( SIGN="0057 97A4
635C C18C 24CA E5C2 E5E9 1A00 44AF 16CD 8FDE E891 D2D5 5647
302E" SIGN2="0067 3FE7 20EF CB4F 678F B4C0 27CC 3A00 86DD E087
5524 97A1 E781 67A1 774C") }
INCREMENT electronics2d_gui ansyslmd 9999.9999 31-aug-2019 5
LK=9FD98A8CD959 SIGN2="00EC 1CE6 A56F 32C0 0DD9 6C17 839D F100
EA1F 1117 D167 E0CC B2A7 1FE3 3040") ansoftd=( SIGN="002E 7B52
D838 5192 CA6A 2060 91E0 4F00 536B E599 8ACE F7B9 1299 3F3C
396E" SIGN2="00A3 41B0 7C52 8AF9 E792 B15F B8CB 1E00 AF84 8A22
19BB 137C AB82 70DE 054B") }
INCREMENT electronics3d_gui ansyslmd 9999.9999 31-aug-2019 5
LK=C02D37777EEF SIGN2="003F 3D88 64E1 F32E 8CEC E3E2 3A09 3A00
C035 E7C0 422E 4CBA 7821 D12C 7195") ansoftd=( SIGN="0044 3443
6C50 EE39 DB21 4F3A EECA 4E00 6495 9D9E DE00 F94C 60F3 4531
5C4F" SIGN2="0091 1BFB C568 1FD9 D9A2 C61A 0F7A 6600 0085 989D
68D8 58E8 7B63 D0C3 F0D1") }
INCREMENT electronicsckt_gui ansyslmd 9999.9999 31-aug-2019 5
LK=DDACF6BB8285 SIGN2="009D 3AEB 9090 4338 DC36 718B AB50 0200
2073 2D0E CFC7 6299 6E07 F4DE C1A3") ansoftd=( SIGN="00E7 4A2B
651C CEBF CA0B 8918 36B5 F000 63B2 855F 3772 542B 2F79 8DB8
5EB0" SIGN2="003E 5FBC 9936 D4EC 803A 84DD 987C A800 55A2 7D98
DEF7 8DDC 5638 986F 4A52") }
INCREMENT emit_legacy_gui ansyslmd 9999.9999 31-aug-2019 5
LK=0D721A71EA08 SIGN2="000E 2265 192E 2D8E C343 A09A D965 FC00
4239 8CAB 0DE3 7C21 38C4 D5DB F1E8") ansoftd=( SIGN="0093 CFD2
9F19 4AE2 100F 122D 7041 4700 2A15 7066 38A8 F8C8 0C92 0E68
0ABB" SIGN2="0088 3D4E 7FA9 02DC 71F3 08F0 0A8A 1A00 7FCB 866C
3567 3AFC 9FF1 096B 4504") }
INCREMENT emit_solve ansyslmd 9999.9999 31-aug-2019 5
LK=96C4120B1ABE SIGN2="000C 3261 3A5F 0B90 0736 E412 7C49 E600
BDD0 0249 438D 2567 326B 3E9A 9A0D") ansoftd=( SIGN="004D E0EB
4FA9 E373 2154 2F1D 5388 EC00 F5B5 6E80 50BB 517B F1F6 D451
96F2" SIGN2="003E 4499 784F 804E D820 B462 4236 3600 3C92 0511
3215 5C14 7181 A9E9 BF81") }
INCREMENT ensemble_25_sim ansyslmd 9999.9999 31-aug-2019 5
LK=64DA8824045A SIGN2="0096 CE47 F3BE C8F9 2B4B 5FA9 4BF4 0800
5F8F E37F B700 63DD DABE BEDF E56F") ansoftd=( SIGN="00C5 C077
134F FCD0 0BDC 1B39 F2AE A600 6259 A4C2 E3B2 A1BE B85A E29E
74EA" SIGN2="0001 84B8 88AC 512A EE7C 6215 F54F 8A00 B989 7912
33BA 8460 34C1 33C8 D07E") }
INCREMENT filter_synthesis ansyslmd 9999.9999 31-aug-2019 5
LK=20E00132BF6F SIGN2="002F 1CEF F525 BE84 1DB3 4734 9A0E D200
E154 9877 44AE B354 C6EA 03AF 9956") ansoftd=( SIGN="001A C928
D11A D09E 59B8 56DA 2B6C 3600 236B D2C6 A662 202A 6DD2 1B48
7D80" SIGN2="000B 7D7A 7F2B A619 0578 5ED4 C747 6400 0F42 2DB6
3EBF EDB5 84C4 01FF E4EA") }
INCREMENT hfss_solve ansyslmd 9999.9999 31-aug-2019 5
LK=0CFFA94C200B SIGN2="006F 5A78 FCE1 99B7 0D45 D9FC 8B0C 7200
E3CC 5976 24DF 91AD 67A6 F6DB F265") ansoftd=( SIGN="004D 9827
05A8 A76F 8D75 ABA5 F699 B200 62CD D19D 905F A8C4 9D53 9D24
64A6" SIGN2="0041 0FAC F381 F9B0 1210 9786 804F B300 2350 8D2A
3C3C 1939 CF1B 914A C170") }
INCREMENT hfss_transient_solve ansyslmd 9999.9999 31-aug-2019 5
LK=5ECA05270C8D SIGN2="00AF 7D25 0484 D8E7 A14E D1D9 D032 7B00
3AC7 0C3D 12EA E12B 1BEC 57B3 2D67") ansoftd=( SIGN="00C4 EF8A
B93A A052 0CFA 2FE7 6F8F 5000 4CA8 625B 4623 4787 4E23 0E4E
E381" SIGN2="006B EAF0 E531 6993 2409 D098 9D90 8B00 3FA7 A3F7
2084 3180 FCC7 52BE 3C40") }
INCREMENT hfsshpc ansyslmd 9999.9999 31-aug-2019 80
LK=3CD5FC60C03B SIGN2="00DE 053D 2B0C AF9F FC46 40FD 2656 2D00
B2AF 3F3F 8AF6 9E55 8C17 6DAB F534") ansoftd=( SIGN="00A9 6FAB
2842 C078 0CFE 01A7 E147 8B00 0A7F 67CE 8F54 784F B7BC 1715
7423" SIGN2="00C2 2D34 AFFC 808A 4E09 5179 CC8D CB00 75E7 CB7A
8B15 547D 2ED2 E083 5844") }
INCREMENT hfsssbr_solve ansyslmd 9999.9999 31-aug-2019 5
LK=AEC97ED69DD3 SIGN2="0055 7B4A CC12 A4C3 DF17 388F 1DB1 CD00
3C1F 96BD 94D8 E358 9B3A C9D5 6CBA") ansoftd=( SIGN="0012 AF32
5697 64D1 A69C 75A8 4B8D C600 6E8B ED90 2C2B D629 0639 D2B8
774E" SIGN2="0064 1F64 B044 812C 99E9 B06A 3691 1D00 3B4A 8305
5506 3F06 FF54 74AC 780E") }
INCREMENT nexxim_ami ansyslmd 9999.9999 31-aug-2019 5
LK=E0C8CCDC822F SIGN2="0031 101C 057B AA43 0569 D373 C2BD F600
975F F5B3 0B24 7308 CE3C 0782 2265") ansoftd=( SIGN="005F DEB9
5BBC BF2D F388 7F9F 815B B200 916D BFE5 BE1E B614 83A9 D421
C7CB" SIGN2="00DD 223D F692 D7A3 5F78 82ED D125 7B00 E1B9 A6C4
2719 ABD1 5921 8916 6584") }
INCREMENT nexxim_dc ansyslmd 9999.9999 31-aug-2019 5
LK=119C0956FDDA SIGN2="000D 0219 EA33 EEEF 88B7 B785 BE79 1F00
DD7E F08C 0FF5 5532 0A10 F3A8 09E9") ansoftd=( SIGN="0033 FB45
C214 F929 3742 CE59 9F02 7D00 8181 3E04 15A2 C47C 48C3 6E19
F38B" SIGN2="0031 5913 58C3 8683 DD55 7D95 85A3 E900 E7A3 704E
C00A 3E7A D129 E6CC B92D") }
INCREMENT nexxim_eye ansyslmd 9999.9999 31-aug-2019 5
LK=8B4AE480041C SIGN2="001B 3DEC 8301 EC37 97F9 22E4 FC7A 5800
8541 B801 561D 7D2A F7E1 FB80 B826") ansoftd=( SIGN="009A 9529
C468 00CF D1C9 3E43 E57A 9A00 A8BA DE0A A9F6 BAF9 CB91 0717
C923" SIGN2="00A6 C6D4 91C2 1044 40B9 54D3 FAEB 4900 27CC FE83
BA75 8943 1694 F7A0 AE08") }
INCREMENT nexxim_hb ansyslmd 9999.9999 31-aug-2019 5
LK=30EB6B955978 SIGN2="0031 7E07 FFCF D3E1 8CF8 70A2 14A7 0D00
B4AA 52FA AC88 A9DB 0BD6 2B0D 0144") ansoftd=( SIGN="00A4 F6BA
E42E DBEA 8249 B8AD 4C86 5300 5138 0C68 4ECF 9ECD 9F67 7639
A139" SIGN2="001A F225 9E49 729E 9F6F 83C1 3443 DB00 E6E7 970D
CC8B F49E C2A6 3518 E6D6") }
INCREMENT nexxim_netlist ansyslmd 9999.9999 31-aug-2019 5
LK=189F15EF2DE9 SIGN2="00ED E583 AE7C 54BD 77C4 9A15 E0FC FA00
4042 E945 39DD DBA7 7DD2 2B52 ECC7") ansoftd=( SIGN="00E9 E57D
6E23 44FD 8680 6970 51E5 D400 189E C8BB 3BFC 1091 0933 4596
1C95" SIGN2="0015 33BB 4154 08BF 0863 12E6 09F8 2100 38C7 1233
7DE4 CE7E 7B4E 6F58 400D") }
INCREMENT nexxim_osc ansyslmd 9999.9999 31-aug-2019 5
LK=79E326A05604 SIGN2="00F1 EF86 035E 93CF 4A89 AE9C 46CF 9D00
7B72 DC1B 7016 95F6 3FAE 4932 C7D0") ansoftd=( SIGN="0008 9B09
8C7D 3A4D 4260 CEA5 9F49 2200 06F4 8637 9777 9F62 AC4A EE5F
D717" SIGN2="004F F5A4 D494 EB1B 7154 C329 E099 6900 DD1A 9A7D
BBF0 ACD1 D38E 5746 1C79") }
INCREMENT nexxim_tran ansyslmd 9999.9999 31-aug-2019 5
LK=01913D46CB49 SIGN2="00BE 775E E491 D156 0B4E 56B4 ACFC CE00
1DE0 8AB3 3852 E3D3 CB32 14C3 4135") ansoftd=( SIGN="0088 DB86
3876 253B AB11 80AD 65DA D800 00FC B49B 9E97 9767 08FF 4F4E
3D29" SIGN2="00E2 12CD 1F35 314C 14D5 8CC2 9BAA BF00 8DDE C802
1598 0AD9 DC21 8A33 0BC7") }
INCREMENT nexxim_tvnoise ansyslmd 9999.9999 31-aug-2019 5
LK=3FC7869613E0 SIGN2="0085 9888 C898 5243 304F C70D C160 6C00
9DE5 16FF 135B CCAE 4370 7FFB F03F") ansoftd=( SIGN="00D7 6534
4E95 1906 1CD1 1024 3740 2800 AF4A 74FD 9E7E B1C0 973D 3FF9
9F8B" SIGN2="006E D0B8 E62E BFBD 7C74 20DC EBF9 3800 D13B 0E41
DD6E 6DC2 B4BC 6E3D C1A7") }
INCREMENT optimetrics ansyslmd 9999.9999 31-aug-2019 5
LK=CF31B5B6F8D4 SIGN2="009F C7DD 832D 373D A2CB A80D 9DF5 2B00
3616 E955 E8B9 F43B 7C2B 4B16 5D68") ansoftd=( SIGN="00E0 DF58
55A9 1A1C 1F26 1B2B 041F B600 44DF 3C5B 3557 083A 793A F649
849E" SIGN2="00C0 24EB CC81 6B12 5619 6A7F 5794 E700 8156 BB95
E0A7 F323 1A36 FFFC 74FD") }
INCREMENT savant_legacy_gui ansyslmd 9999.9999 31-aug-2019 5
LK=AACED0975242 SIGN2="00C1 7340 6F49 4906 C52B A389 0BB1 4000
2031 0CA1 8720 2DA3 FAF9 EC34 709C") ansoftd=( SIGN="00BE A332
C77A 579E E8DD D78A 8A72 F900 C539 89D9 BB6B D641 AE49 B516
773E" SIGN2="0067 9D9D 45E9 8B99 E19C 1C3C 9498 E600 3DA9 DB5F
C5B8 CA94 4A7C 4AEB F72D") }
INCREMENT si2d_solve ansyslmd 9999.9999 31-aug-2019 5
LK=F56241611FAD SIGN2="00D0 592F 4A50 2F26 9BAD 57B1 76E2 A900
1BF9 6134 337D B22E 3903 9D53 6979") ansoftd=( SIGN="0093 970E
B014 F634 249D E850 EE4F BB00 F68C 799F E1B6 8BF2 34A5 804F
E888" SIGN2="007D 7ADA 0250 5347 3FB2 711D F736 0C00 1C85 65EA
EAF4 171B 607F 92D6 D0C4") }
INCREMENT si3d_solve ansyslmd 9999.9999 31-aug-2019 5
LK=5E0C18930EA7 SIGN2="0050 BC13 B313 0DF3 24D9 0AC0 D295 0400
5DDF 3D33 5CE7 B589 7BBA 5DB9 B496") ansoftd=( SIGN="008B 3974
978F 010E F716 4DC1 A377 9800 2274 18FB 8DB7 BF44 1E9B A686
B434" SIGN2="0065 B052 354C 0499 7FA7 53E3 61E9 C600 21CB 2C3F
E54A 5DA5 3F42 34E4 FE2D") }
INCREMENT simplorer_gui ansyslmd 9999.9999 31-aug-2019 5
LK=9C52C261B2C9 SIGN2="0099 4617 9CEC D221 8540 D91A 32B5 5700
D2F7 3ADB EA69 B41C 591A 863F 9FFC") ansoftd=( SIGN="00B9 47FF
D5F2 261A 7100 F8FD 0B00 7000 7CF4 F227 88DA EA18 2C8A DA02
38B8" SIGN2="00C8 DCEC 814A A448 00C2 0D6F 1BB3 8B00 7E61 D50B
2D5D 3B50 11D4 5558 4548") }
INCREMENT siwave_gui ansyslmd 9999.9999 31-aug-2019 5
LK=A00C72EEE6CC SIGN2="000D 016F CD41 5689 BA44 74F2 0850 5400
7265 A7D3 A45C E026 6CE0 1B17 64D4") ansoftd=( SIGN="00B9 20E2
B67F 1CD5 6697 1AF9 76F3 8100 871B 0DBB 18FF 3827 2C4E 1EE5
3110" SIGN2="0088 B97A 196C 7D73 5676 3F63 02CF EE00 2545 0C6B
B100 57AE F722 2418 2083") }
INCREMENT siwave_level1 ansyslmd 9999.9999 31-aug-2019 5
LK=6766603CB2CB SIGN2="00CE 48B9 58DD 10FF 3610 A1BD 0120 0500
F5AA 895B DD4E 914C 3BC4 DA01 8D79") ansoftd=( SIGN="0034 25F6
DE82 252A 8768 4BFC 289E C700 3DB6 155B 60B5 ACE1 2849 CA2B
CE59" SIGN2="0093 83B1 5437 DD60 C09D 63C3 0776 1300 49B5 1CDD
1366 812C 84DB C67E B1C9") }
INCREMENT siwave_level2 ansyslmd 9999.9999 31-aug-2019 5
LK=81B3A9372C34 SIGN2="0075 C525 773E B16C 8271 ECD2 074B 6F00
1178 734A C2C0 D344 D313 954B 885E") ansoftd=( SIGN="0016 C341
3EC5 277A 73F7 36D7 A14E D600 E62C 2AD4 D1C0 6ADD 63ED 8498
2ED6" SIGN2="00C7 FD49 3660 27EE 0CD3 D906 BEB0 B000 DD79 C9F2
8945 7538 68FD 1BC7 5F24") }
INCREMENT siwave_level3 ansyslmd 9999.9999 31-aug-2019 5
LK=FB8732D83768 SIGN2="0060 0249 6ACF DEE1 FD37 3099 9551 7100
0D27 7E32 B044 4D57 FBD1 7724 B02D") ansoftd=( SIGN="0058 3B4B
6C7D 2D9D EAF0 AF9B 142B F300 6AA8 4735 3A3A 1E27 4926 9E86
205A" SIGN2="0048 67D0 C4E0 F7AE 45C4 1484 E6B2 3C00 BF73 2560
9EDB A84B 5AFE DE6E 7811") }
INCREMENT symphony_dt_sim ansyslmd 9999.9999 31-aug-2019 5
LK=EDFBFDF39B63 SIGN2="001C A751 6F67 C97E AEAC 7D8A ABE9 0800
12B4 CAAD 8920 09F9 B5C0 714A 1230") ansoftd=( SIGN="00EB F7C0
5F10 8613 A94A 3B6D B0C0 CD00 5991 D70F 168C 4C38 34AE 4AEA
2977" SIGN2="004F A1A0 91CA 8F40 43EC AC2A 0744 DD00 5C41 770D
96E1 7458 2B20 E57E 321C") }
INCREMENT symphony_fd_sim ansyslmd 9999.9999 31-aug-2019 5
LK=BEA8A39B1C01 SIGN2="00D7 138A 5139 0249 4783 60EB 1ABC 0600
76AC 2C55 2DC1 B38F A810 860D 7815") ansoftd=( SIGN="00E1 65D9
F281 2E5F EDE0 1D76 95A8 8000 294C 532F 8619 945E 8B65 CE43
2930" SIGN2="004A 7AAB 2018 18E9 6384 9F75 BE5C AA00 B617 3DFD
7B79 1FF9 2EE6 64EA D013") }
INCREMENT xlate_catia4 ansyslmd 9999.9999 31-aug-2019 5
LK=8ED2B48A8091 SIGN2="002A F5D6 37DC EBD2 9DBE C7F2 84F3 CB00
7397 9815 0832 FF59 D486 7663 688D") ansoftd=( SIGN="006A 3906
B9D8 A504 9AA3 6668 78FE C200 1D05 3FC3 4D78 669C 003F 28BD
1DDE" SIGN2="0024 C07C ABFD A34A B957 EA4E BB72 EB00 F7C4 90CF
7B8E 7A24 E229 8D28 1CA3") }
INCREMENT xlate_catia5 ansyslmd 9999.9999 31-aug-2019 5
LK=937BC70D64D6 SIGN2="00FB EB9A D1FA 102C 5265 C99D 33A9 5B00
0BA7 B924 5BE0 8D58 0972 236B D1EB") ansoftd=( SIGN="0042 60A7
D5BE 6CCF 7FAD 99D2 650F CD00 2C64 2BCB C499 F1B4 14B9 1D68
DD0A" SIGN2="002C 23D4 AB45 EB85 2755 9BC5 7A10 1200 A327 4572
6FD8 88F1 09AB DAA8 A7A5") }
INCREMENT xlate_iges ansyslmd 9999.9999 31-aug-2019 5
LK=6FDB368A540C SIGN2="00D8 23DE 28A1 48A0 5F0B A249 7A1E D800
0C8A 7FA0 406B B7AB E259 1A3E 65EA") ansoftd=( SIGN="0063 172C
0EC3 8DD2 855B AA96 9320 1000 5921 53FE 67C2 1F8C 7BDF 4BF4
FFA3" SIGN2="00F2 496D CA97 67F0 A403 DC8D 6E78 0100 F36A A5A6
37FD D08B 573B C95C 5C75") }
INCREMENT xlate_inventor ansyslmd 9999.9999 31-aug-2019 5
LK=5B7EEA9274ED SIGN2="00A7 5DDB 014D 322C D449 5B60 0A2C 7800
2996 254F 52E4 1B3A F790 9FA3 665B") ansoftd=( SIGN="00F4 AE1F
E2C7 63F4 CAC5 C228 93D5 5F00 A77B FCCD 9EE5 B45A 6CB4 5218
E115" SIGN2="007E C76C B866 F595 BD42 47BB 4BC0 CB00 FD71 2C25
D829 DD06 5071 7BCF 158B") }
INCREMENT xlate_parasolid ansyslmd 9999.9999 31-aug-2019 5
LK=C3CE2D61275E SIGN2="00E9 12FD 7FA4 26A1 3F3A E41E 0613 8A00
848A 30CB CB7D 06DE 0DFF 23D3 CF0E") ansoftd=( SIGN="00DA 0CB5
BE39 5D2C D58D 4409 B928 9A00 8FDA 534A C328 720C 0CC3 E0E7
A03F" SIGN2="0061 579B 01B3 3BF9 1592 0D8F 95EC E900 5CC0 910F
ADF3 4D05 07B6 BE0B 9422") }
INCREMENT xlate_proe ansyslmd 9999.9999 31-aug-2019 5
LK=4BDE2F91C144 SIGN2="00F4 57C5 D9AB 59CB 6E4D B4EA 69C7 A800
1B70 6F1D 69C9 2ED1 E8EF B4E6 841D") ansoftd=( SIGN="00F3 402A
D661 5D1E ECFE 3C59 07C7 3700 001E 7275 0FC3 7962 68AC F14F
A388" SIGN2="00BE 8F84 BBA3 CEF3 E38E 7E2C BC2F 9B00 8463 9A4C
DC32 9967 A9C9 F2A5 D4C8") }
INCREMENT xlate_solidworks ansyslmd 9999.9999 31-aug-2019 5
LK=7CBA61EB985E SIGN2="00B6 4EF0 6DC5 8B17 87A0 9DD1 CE64 9400
1551 CABF 5C4C 1E3E 09E6 4D7F 79B8") ansoftd=( SIGN="0050 3701
673A 94CD 9458 EA7D CEDF 5C00 4403 56F8 676F 4B67 827D B4CC
6E8F" SIGN2="00DC 8AF9 72C6 D4AA E762 387C 33E5 E500 60D0 D7BE
2E02 6297 D34B E006 563F") }
INCREMENT xlate_step ansyslmd 9999.9999 31-aug-2019 5
LK=C85012944E4D SIGN2="0092 F783 4CD2 3B51 E344 66A2 7DCD 3F00
85AE 1888 1415 D25F D951 97BA 0C7A") ansoftd=( SIGN="0093 C833
35E1 BBD8 7268 5FFC ED53 2E00 E409 C6B1 F345 FB7B 0EF3 1091
F610" SIGN2="005B 665A 802F B132 1BE6 8210 0023 6400 99D2 212E
24C0 08BF FC4F 94FF 8BED") }
INCREMENT xlate_unigraphics ansyslmd 9999.9999 31-aug-2019 5
LK=0325431463E4 SIGN2="0011 EE1E 2C08 8602 B528 BFA3 DC00 7400
338E EACC 9905 C157 C215 D845 BC25") ansoftd=( SIGN="00C6 0125
D662 26C0 80ED FC0E 4A75 0700 7E68 7998 1203 58CF DECC 37FF
2C35" SIGN2="00CD 8B14 514C C692 C181 1F69 C835 9F00 5506 5679
33A3 6DE7 2E9F 9430 97E7") }
October 31, 2018 at 9:36 pm
tsiriaks
Ansys EmployeeIf the License Manager is not saying
Licensing Interconnect: running
Licensing Interconnect Monitor: running
FlexNet Licensing: running
it means it's not running and, of course, the software can't run because the license server is not up and running. Even though port between these two machines is open, there is nothing to send-receive.
Please ask your server admin of ECCANSYSLM to look at
ANSYS License Management Center -> View Licensing Interconnect Log
and
ANSYS License Management Center -> View FlexNet Debug Log
These two logs will give them some clues what the issue/error is.
Thanks,
Win
October 31, 2018 at 11:44 pm
Osama10
SubscriberHi Win,
The server admin says that: "the license file doesn't have licenses for the product in question.. Literally every other thing on the license file works, so there is also nothing wrong with the server. If you think this is in error and you paid for this product, you need to have ANSYS send the correct license for the module purchased. Until then, we can't just make a license appear."
Could you please confirm that this license is not for HFSS and what should we do in this case?
Thank you,
Osama
November 1, 2018 at 12:52 am
tsiriaks
This license does include 'electronics_desktop' , which works for AnsysEM v16.2 or newer as mentioned earlier. But since your 19.2 doesn't work either, there is something wrong.
Can you confirm if this has been done ?
(Linux) /ansys_inc/shared_files/licensing/license_files
Two keys from this statement are
1. Your server admin must set the vendor port on the license server machine as instructed
2. Your machine must be able to communicate with the license server via the port that is being set in #1 . You can ask your network IT to check this or you can confirm it yourself using 'telnet' command in the CMD Prompt
telnet ECCANSYSLM
I'm guessing this port may not be open. You can compare the result with port 2325
telnet ECCANSYSLM 2325
if it works , it will show you a blank screen. If not, it will say what's wrong.
Note that your machine may not have telnet feature turned on. You can turn it on by typing Windows features in "Search Windows" tool box , then look for "Turns Windows features on or off" and launch this. Then, scroll down to the bottom and check "Telnet Client" > OK
Thanks,
Win
November 3, 2018 at 3:33 pm
Osama10
SubscriberHi Win,
It is working Now using Electronics Desktop v. 19.2
Thank you very much.
November 5, 2018 at 6:37 pm
tsiriaks
That's excellent news ! I'm glad it's working for you now. Thank you for the update.
Thanks,
Win
- Workbench error
- Workbench not opening
- License Error
2600
2086
1317
1108
459
