July 20, 2018 at 4:58 pm
raphaelc
SubscriberWill HFSS run better/faster on Windows 10 or Linux?
July 20, 2018 at 11:50 pm
slouie
Ansys EmployeeYou should see comparable simulation times on Windows and Linux. When it comes to the hardware used to run HFSS as fast as possible, your main concern should be number of cores and amount of RAM available to you - regardless of the OS.
- Maxwell, HFSS or Q3D?
- Error
2684
2124
1349
1136
461
