May 11, 2022 at 5:05 pm
mriheen
SubscriberHi,
I am trying to simulate an antenna placed on a FR4 substrate (snapshot attached). PCB top and bottom layer are metal connected through VIAs. For this case, to assign a port, I have just drawn a rectangle at the edge of the PCB having a width same as the feedline and length same as the PCB height.
Is it the correct way of assigning lumped port for my case ? If not, would you please tell how should I assign the port accurately?
May 16, 2022 at 7:12 amChinmay T
Kindly do not createduplicateposts. We have answered your question here.
How to provide lumped port for grounded CPW? ÔÇö Ansys Learning Forum
As this is a duplicate post I am closing this.
Thanks Chinmay
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8740
4658
3151
1678
1452
