May 19, 2022 at 8:46 pm
rpm4158
SubscriberIve used Editor.GetModelBoundingBox() to get the X, Y, Z start and end coordinates of a full model after importing it and can access the array values in a vbs script but is there a way to get the same data of a single object in the 3D modeler environment? The specific 3D object is made of 4 polylines and swept along a vector.
May 31, 2022 at 6:26 pmPraneeth
Please provide more information on your issue to help us serve you better.
What do you mean by the array values of the object.
If you want to see the dimensions of the model then you can use measure modes available in the draw ribbon.
Also in the bottom row of the interface you can see the X, Y, Z co-ordinates while drawing the geometries.
All the very best Praneeth.
- Maxwell, HFSS or Q3D?
- Error
3744
2570
1789
1236
594
