March 28, 2022 at 4:21 pm
Hyperion
SubscriberHow might I implement a port on a microstrip that does not have a ground plane along the entire bottom surface of the substrate? I'm quite new to HFSS and don't know exactly what to use. I'm trying to get the field patterns and S parameters for an RFID antenna. It has two ports, and it's possible that one is meant to act as the ground point and the other as the active portion, so I have tried putting a lumped port across the two and a voltage source across the two as different options. Neither seems to work, but it may also be due to a lack of understanding of the needed integration lines (I seem to have a hard time finding what exactly they describe and how to set them up).
March 30, 2022 at 11:48 amAnchal Singh
May I know how you provide a return path for the signal if there is no ground plane? You must have a ground plane in your design not necessarily at the bottom of the substrate but it may be there in the same plane where the active portion of your design lies.
You may follow the course Ansys HFSS Port Types - ANSYS Innovation Courses to have a better understanding of ports types in Ansys HFSS.
Hope this helps
Thanks
Anchal
April 8, 2022 at 9:29 amHyperion
SubscriberHello Anchal This antenna has two ports, one of which is a feed-in and the other end of the lumped port is on the other port. Thanks for referencing those courses - unfortunately I'm still having no luck.
H
SubscriberHello AncSingh This antenna has two ports, one of which is a feed-in and the other end of the lumped port is on the other port. Thanks for referencing those courses - unfortunately the antenna simulation still does not match what is expected. Below is a simplified version of the antenna I'm trying to test.
- Maxwell, HFSS or Q3D?
- Error
2726
2156
1359
1150
462
