March 8, 2021 at 7:01 am
park0415
SubscriberI want to know why the resonance disappears when I set the higher mode.
When the simulation was conducted without setting the higher-order mode for the first time, resonance occurred at a specific frequency.
March 8, 2021 at 7:28 amPraneeth
Ansys EmployeeHi Array,nYou can make use of edit sourcesoption under excitationsfolder to excite required mode from the available modes.nKindly go through Scaling a Source's Magnitude and Phasein the HFSS Helpdocument for more detailed information.nAll the best.nBest Regards,nnViewing 1 reply thread- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1285
1096
459
