January 26, 2023 at 4:48 am
Jesus Guzman
SubscriberI am trying to determine the input impedance that is mesured line to line of long pair of traces to see the effects of planes coupling onto the pair. What is the difference between the reported Z-parameter value for a terminal and differential pair? Different values are measured depening on the type that is selected whether that is the differential pair {zt(Diff1,Diff1)} or terminals {zt(SIG_T,SIG_F)}. Is the stimulus that is applied different between the type that is selected?
- Maxwell, HFSS or Q3D?
- Error
2524
2064
1279
1096
456
