August 29, 2019 at 5:03 am
huyrua291996
SubscriberHello everyone,
I am simulating an electrically small antenna for 433 MHz. I decide to use length of lamda / 10 because of my limited board.
But my result of S11 is not true at 433 Mhz. Must I set up like radiation box, mesh or sth to make it right
Thanks
September 4, 2019 at 4:03 pm
slouie
Ansys EmployeeWithout any knowledge of your design, it's hard to say what the problem may be. However, for very electrically small antennas, it's possible that you may need to incorporate some matching elements into the design to achieve the resonance you're expecting at 433MHz. Hope this helps.
- Maxwell, HFSS or Q3D?
- Error
2524
2064
1279
1096
456
