March 10, 2021 at 9:23 pm
stefy123
SubscriberHi, I am trying to run the TriHedral_RCS example. But I get the following error:nn MonoStaticTriHedral (DrivenModal)n [info] SBR : LastAdaptive distributing Domain Solver (3:16:10 PM Mar 10, 2021)n [error] Savant Internal Error: Error: unable to create archive file: mpi.savantarc at ZipFile.cpp::446 build: 0 - 2020-11-06 22:06:29 (3:16:16 PM Mar 10, 2021)n [error] Error solving SBR+ region! (3:16:16 PM Mar 10, 2021)n [error] Simulation completed with execution error on server: Local Machine. (3:16:16 PM Mar 10, 2021)nnCould anyone help with that? Thanks!nn -
March 10, 2021 at 11:06 pm
Zeba Naqvi
Ansys EmployeeAre you able to run other HFSS models? Try running a simple SBR+ simulation - make solution type SBR+, create a PEC object, use plane wave as excitation, add setup for monostaticRCS and analyze for some freq. Does it solve or throws error?n -
March 10, 2021 at 11:50 pm
stefy123
SubscriberThanks for the reply. I set up another project as you suggested and it is still giving me the same error:nn HFSSDesign1 (SBR+)n [info] Setup1 : LastAdaptive distributing Domain Solver (5:47:49 PM Mar 10, 2021)n [info] Setup1 : Sweep distributing Domain Solver (5:47:49 PM Mar 10, 2021)n [info] A discrete frequency sweep with 1 point(s) has been started using HFSS. (5:47:50 PM Mar 10, 2021)n [error] Savant Internal Error: Error: unable to create archive file: mpi.savantarc at ZipFile.cpp::446 build: 0 - 2020-11-06 22:06:29 (5:47:56 PM Mar 10, 2021)n [error] Error solving SBR+ region! (5:47:56 PM Mar 10, 2021)n n -
March 12, 2021 at 3:03 pm
Praneeth
Ansys EmployeenPlease share the version of the tool and your system configuration to help us serve you better.nIt looks like you are running out of space on hard drive.nAll the best. nBest Reagards,n
Viewing 3 reply threads
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2590
2080
1315
1108
459
Top Rated Tags
