June 29, 2020 at 3:53 pm
underground45
Subscriber -
July 1, 2020 at 12:44 pm
VivekKamble
Ansys EmployeeHi,
The antenna resonance frequency depends on many parameters such as the length & width of the patch, the height of the substrate, etc.
You can optimize the design by using Optimetrics in the project manager window.
Right-click on Optometrics >> Add parametric then add parameters and Analyze.
Please refer HFSS help document for more information.
- Maxwell, HFSS or Q3D?
- Error
3720
2570
1777
1236
594
