January 6, 2023 at 5:26 pm
hyunjun
SubscriberHi.
I obtained the theta & phi component of realized gain from dipole antenna simulation.
And I calculated the x component of realized gain from theta & phi component by using transformation relation between spherical and cartesian .
But, x component value that I calculated is different from the value from HFSS.
why..? It would be appreciated in advance if telling me the reason.
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1345
1118
461
