HFSS: Solve problem for select ports?
    • wouter.numan
      Hello all,
      I have an HFSS design with a very large number of ports. Is it possible to resolve this problem for only a select number of ports and have all other ports function as whatever impedance they are set to?
    • Praneeth
      You can access the “edit sources” window by right mouse clicking on “excitations” category in the project manager window. In this window, change the magnitudes of the required ports for your analysis and see the response. For more information on this please go through “Scaling a Source’s Magnitude and Phase” section in the HFSS help document.
      Best regards.
