HFSS Stuck on “Sending solution file: solverUsagefile.txt”
    • wjfoo
      The software was working perfectly last week. However, when I used it this week, it got stuck on at the stage of "Sending solution file: solverUsagefile.txt". The job I was running was a simple job that could run in less than a minute last week.
      When I try to abort the process, HFSS just stops responding.
    • Peter Serano
      wjfoo:
      Check that you are not trying to save the solution to a drive that is out of free space or you do not have write access permissions.
      After checking this: Close all ANSYS programs; Clear the ANSYS temp directory defined at installation; reboot your machine; try running the simulation again.
    • wjfoo
      Peter:
      Thank you for the solution. I tried those steps before, and it didn't really work out. I ended up re-installing HFSS, and the problem went away.
    • Kunchen
      Hi Peter,
      I came across the same problem. Tried the solution you mentioned but it didn't work. I guess I need to reinstall it as well.
    • Peter Serano
      Please let us know if reinstalling the software was necessary to resolve your issue and any other details regarding how/when the issue began.
      There have also been 3 software updates since this thread was first started - what version are you using?
Viewing 4 reply threads
