HFSS: unexpected asymmetric H field data
    • JosiBee
      Hello guys,
      I am using HFSS 3D Modeler to simulate a coil array that is bent around a cylinder with a self defined material. The coil array is symmetrical around the z axis. Nevertheless I get an asymmetrical H field plot (see attached picture). I already changed the material of the cylinder to air, without any effect. I put very high convergence criteria also (max delta s = 0.0025) and a 10mm mesh operation inside the cylinder. Does someone know where this asymmetry comes from and how I can get a symmetrical field? Am I missing a certain setting? I would be very thankful for your help.
      Thanks in advance!
Viewing 0 reply threads
