June 6, 2023 at 7:02 pm
Benjamin Bradshaw
SubscriberI have a question related to implementing Varactor Diodes in HFSS.Currently I am trying to model a metasurface in HFSS which implements a Varactor Diode to change Impedance characteristics of the surface. I've been trying different ways to implement a specific SMV2019-079LF varactor based on its equivalent circuit or other characteristics, but the specifications for its implemented diode do not align with the specification required for defining a diode in the circuit software.What is the best way to go about implementing a varactor in Ansys HFSS? -
June 7, 2023 at 1:49 pm
Dan Dv
Ansys EmployeeTyptically we would recommend that you get a SPICE file for the vacator from the model vendor and then combine that and the HFSS model in a Circuit schematic. Have you tried conecting the model vendor to get a SPICE model for it?
June 9, 2023 at 7:41 pm
Benjamin Bradshaw
SubscriberI have, and I was able to put the model into the Circuit Shematic and simulate it on there. However, for the Metasurface I am using Floquet analysis. Will Ansys Circuit be able to simulate with the floquet analysis?
June 14, 2023 at 3:06 pm
Dan Dv
Ansys EmployeeYes, that should work. There was a similar discussion on this forum recently. Please see the response from Irina G in this thread:
https://forum.ansys.com/forums/topic/optimizing-the-dimensions-of-an-array-element-for-two-states-of-a-pin-diode/
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7626
4442
2953
1427
1322
