December 7, 2022 at 12:09 pm
Joe Suat Chai
Subscriber- For single-ended signal, should I create the waveport individually, 2-in-1 if two traces are closed to each other at CPU escape region or I can create all of them in one same group?
- How to define the value for Horizontal Extent Factor and PEC Launch Width for waveport?
3. If the waveports cannot be aligned, what is guideline to keep for X and Y or as long as they are not touching/shorting each other? Will these overlapping ports cause any additional crosstalk in simulation? - For single-ended signal, should I create the waveport individually, 2-in-1 if two traces are closed to each other at CPU escape region or I can create all of them in one same group?
December 22, 2022 at 11:36 am
Praneeth
Ansys EmployeeHi Joe,
Thank you for reaching out to us and we appreciate your patience.
Please note that we need more details to provide guidance to you on the simulation model. This will be a more involved process as we need to understand the model to guide you. Unfortunately, this cannot be done in this forum.
Kindly raise a service ticket if you have service access.
Best regards,
Praneeth.
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
