October 1, 2018 at 1:01 pm
bamdadslr
SubscriberHi,
I want to model the grounding system of transmission towers in soil in frequency domain. As a starting point, to validate my method, I want to calculate the low frequency impedance of two series cylinder using lumped port in HFSS. Unfortunately I am not getting the right answer. I would appreciate if anyone can help me. Below you can find the picture of what I have modeled.
* An outer cone, to model the ground and close the current loop.
* A perfect_E sheet below the cylinders to model a wire with high conductivity.
- Maxwell, HFSS or Q3D?
- Error
2706
2142
1355
1144
462
