May 18, 2022 at 8:18 pm
Surath11
SubscriberMay 26, 2022 at 11:05 amNavya C
Ansys EmployeeHi @Surath11 The total current, in this case, is the current flowing through the whole coil cross-section.
For example, if you used 2A for current and 200 for turns then a total of 400 A is the current flowing through the coil cross-section.
Regards Navya
- Maxwell, HFSS or Q3D?
- Error
3812
2607
1853
1244
600
