May 21, 2022 at 6:24 am
haj
SubscriberHi friends, I had a question
In Maxwell, if we specify a current for the coils, does Maxwell show us the required voltage? From which option or field?
May 31, 2022 at 4:13 pm
Navya C
You can create an external circuit and measure the voltage.
Regards Navya
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1793
1236
594
