March 28, 2022 at 5:50 am
prabhakaran
SubscriberMarch 28, 2022 at 10:54 amSaumadeep
Employees at Ansys are not permitted to download picture files or any other attachments. Can you please share the image in the question panel instead of it being an attachment?
Thanks, Saumadeep
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
March 28, 2022 at 10:59 amMarch 28, 2022 at 12:25 pmSaumadeep
This seems like a User-defined result. Can you please elaborate on what these variables, ENVM, UA, and SOLN are? and why these variables are used?
Please click on the links for more info on User-defined results:
User Defined Results (ansys.com)
User Defined Result Expressions (ansys.com)
March 28, 2022 at 12:29 pmprabhakaran
SubscriberDear Saumadeep It is user-defined result. I have not used these expressions, kindly explain what this expressions denotes. What is UA and SOLN?
Thanks in Advance
Prabhakaran V
March 28, 2022 at 1:32 pmSaumadeep
As you mentioned this is a user-defined result. So, once a user-defined result is imported, it's mandatory to input the expression, so the expression that you see in your result has been imported by the user.
The expression can be defined as one of the predefined "available solution quantities" (which can be accessed in the Worksheet, please refer to the steps shown in the image below to see how to access the Worksheet). Check all the expressions given in the list as given in the worksheet.
Another way to define the expressions for user-defined results is by using identifiers of previously defined results. (as shown in the image below, where Equivalent Stress is defined by identifier - "a" and Middle Principle Stress is defined by identifier - "b", and both the final user-defined result is defined by expression - "a + b")
Since the terms you mentioned (ENVM, UA, and SOLN) are not in the worksheet, I think they are defined as identifiers for other results and then used in the expression for the user-defined results, as shown above. Please check if that is the case.
March 29, 2022 at 4:38 amprabhakaran
SubscriberDear Thank you for kind support and timely response in this issue.
The explanation you provided is very helpful.
Many a thanks Prabhakaran V
Viewing 6 reply threads- You must be logged in to reply to this topic.
Ansys Innovation SpaceTrending discussions- Saving & sharing of Working project files in .wbpz format
2608
2088
1319
1108
459
