Hi guys I am trying to model additive manufacturing in CFD
    • sai123lesh
      I am trying to simulate the melt pool for LPBF but I don't know how to incorporate the powder bed to Ansys  any guidance will be helpful regarding the same and using User-defined Functions
    • Dubey92
      Hi Sai. You cannot create a powder bed in Ansys. You will have to create the powder bed in some other software like LIGGGHTS and import the particles' radii and coordinate in FLUENT to create a powder. You have to add different source terms in the N-S equation and Energy equation using UDFs.
    • Nikhil Narale
      I am not an expert, but can check if this tutorial example can be used as a reference? See how the fluidized bed is set up. Chapter 24: Using the Eulerian Granular Multiphase Model with Heat Transfer (ansys.com)
      If you are not able to access the link, refer to this forum discussion: Using Help with links (ansys.com)
      If this doen't work for you, let's wait for experts to pitch in.
      Nikhil
      I've only been off a week.... :)
      Both approaches will work, it depends on what you want to acheive. For @Dubley92 's method you can use VOF with the solidification/melting model to avoid the UDF part, but you may want to review how the VOF model works before trying it: you're going to need a big computer & parallel packs.
Viewing 3 reply threads
