November 19, 2018 at 4:23 pm
Noused
SubscriberHi,
what is the 'pin supported' and 'roller supported' boundary conditions at line bodies?
I wanna use that boundary condition in line bodies, but the only one that I can use is 'fixed supported'.
Can you solve this problem for me? I spend almost two hours to apply 'simply supported' boundary condition to line bodies, but not succeed
November 19, 2018 at 4:49 pm
Sandeep Medikonda
Ansys EmployeeHi Please see this post and the subsequent discussion.
Also, please provide an image of the analysis you are doing and the problem you are having?
November 22, 2018 at 4:30 am
Noused
SubscriberSry, I have some misunderstandings about the problem.
I already solve that.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
