high Icing extension with intermittency model
    • muath
      Hello everybody
      I have a problem when I use the high roughness (icing) model instead of standard one. I am simulating 2D flow on rough flat plate the roughness are given as an equivalent sand grain roughness profile.
      the problem that I am getting this massage
      wall_transition_coeffs: Unknown bc type
      Internal error at line 3000 in file 'turbulencesg_ke.c' on Node 6
      and the solution goes very slow. when i use the standard roughness model i have no problem or when I disable the intermittency equation.
      will be great if someone helped me with this issue.
      thx
    • Konstantine Kourbatski
      Hello According to Sec. 7.4.15.2.8.2. "Additional Roughness Models for Icing Simulations" of Fluent 2020 User Guide, the high roughness model is compatible only with Spalart-Allmara and SST k-w. it is not compatible with transitions models
