February 9, 2023 at 1:08 pm
Marcos Garcia
SubscriberHello all,
I'm running a static simulation with bolted connection using beams, from the contact section. When i solve the simulation, I have a so big stress in the edge of the hole, which is clearly a stress concentrator. Is there any way to improve and eliminate this stress concentrator or should I just ignore this value?.
Thanks in advance.
February 9, 2023 at 4:36 pm
SaiD
Ansys EmployeeHello,
Are you tieing the vertex of the beam connection to the edge of the hole? A better way would be to create imprints of the bolt heads and tie the vertex to that 'area' instead of an 'edge'. You may find this lesson helpful: Bolt Modeling Connections as Beam Elements | Ansys Courses
February 10, 2023 at 6:25 am
Marcos Garcia
SubscriberHello,
You are right, I'm applying the beam connection on the edge of the hole. I will try to use the imprint command in SpaceClaim to generate a circular surface around the hole to use that surface to define the beam connection, in the same way that the video that u showed me.
I have a question about the imprint generation, I know how to do it in planar surfaces but I dont know hot to generate this imprint for curve surface like in the model that i have. Could you say me how to do the imprint in curve surfaces?
Thanks in advance.
February 10, 2023 at 10:11 am
February 10, 2023 at 4:01 pm
SaiD
Ansys EmployeeThanks for sharing your method! Hope others find it helpful.
3744
2573
1821
1236
596
