Discovery Import
Discovery Import
Hole table
    • Roberto
      Hello
      is it possible to move the origin to a location other than sharp edges? For example center of holes or other points? As it is now limited
      Video https://www.screencast.com/t/uv07RiG7u
      Best Regards
    • Naresh Patre
      Hello Roberto
      I don't think the origin can be moved at any arbitrary locations. When you select the origin circle (red color) and start to drag it, all valid locations are highlighted which can be used as origins for defining the hole table. These locations are mostly the corners of the geometry.
      • Roberto
        Naresh Patre Hello
        I will propose it as an improvement
        Best Regards
