June 19, 2023 at 4:11 pm
tade
Subscriberhello.
Is it possible for lumerical Charge solver to calculate the tunneling holes from a metal through an insulator to a semiconductor by making use of band to band tunneling model?
June 20, 2023 at 4:37 pm
Guilin Sun
Ansys EmployeeI am not sure what does the tunneling holes mean here. However CHARGE can simulate tunneling effect in the "Recombination" tab, including band-to-band tunneling. Here is an example https://optics.ansys.com/hc/en-us/articles/360042760453-Metal-oxide-semiconductor-field-effect-transistor-MOSFET-
more information for semiconductor: https://optics.ansys.com/hc/en-us/articles/360034919113-Semiconductor-Material-Model-Properties
However, both metal and insulator do not involve in meshing and simulation as metal is considered to be perfect and its shape almost does not effect the results. Insulator does not support charge therefore it is not meshed, except at the interface of the semicodutors where the surface loss can be set.
- Error on Lumerical device
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Lumerical – error message when trying to open from Linux terminal
7624
4442
2953
1427
1322
