April 18, 2020 at 9:30 pm
vagraw13
SubscriberI'm analyzing a honeycomb unit cell using periodic boundary conditions for a representative volume element. I have its inner hexagon inscribed circle radius and thickness as the varying parameters. I designed the cell using Python Scripting in SpaceClaim and parametrized both the dimensions there (see image). After simulation in Static-Structural, I want to perform DOE, but it's not working. I'm getting the same output values for all the combinations of input parameters. Those output values are for the geometry I initially made in SpaceClaim. I also tried name selection in SpaceClaim but it's still not taking any different input values. Also, it's showing 0 as the initial values in the design table. I'm using ANSYS 19 R3.
Please help.
Thanks & Regards
Varun
- SpaceClaim Teaching/Curriculum Materials
- Attaching 2 Objects + moment of inertia with/without point mass
- Honeycomb DOE using parametrization in SpaceClaim
- time history analysis
- Recording spline line in script editor
- Surface Definition
- Geometry not a single unit
- Spaceclaim equations: How to insert the log functions
- Facet Issues
- Solidworks&Parameter
2656
2120
1347
1118
461
