May 12, 2022 at 5:16 am
ctapia
SubscriberHello,
I am trying to setup a license server on my team's computer in our workspace. Ansys License Management Centre has the license manager running. I then updated the license on another computer by connecting using the port and server name on License Client Settings 2021 R2. However, I was getting the error: "Error getting status: License server machine is down or not responding".
In terms of the steps that I have done on the hosting computer, I followed the instructions I received for activating the entitlements:
1. Log into the Ansys Licensing Portal using your Ansys Account credentials.
2. Add your license server machine hostid if it does not exist, and download your license file.
3. Install your license file on your license server machine.
What am I missing in the setup?
May 12, 2022 at 7:58 pmGeorge Karnos
Ansys EmployeeThe first 2 lines license file should look similar to the following (hostname is the hostname of the license server and hostid is for the License server, those should be correct)
SERVER hostname1055
VENDOR ansyslmd PORT=1056
Check firewalls. Ensure all ports 1055, 1056, 2325 are excluded.
Verify that you can ping the license sever by hostname from the client machine.
Viewing 1 reply thread- The topic ‘Hosting a Server License: “Error getting status: License server machine is down or not responding”’ is closed to new replies.
Trending discussions- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8808
4658
3153
1680
1470
