March 19, 2021 at 6:58 pm
prakhars962
SubscriberI was simulating a strip footing using plane strain idealization with bilinear Isotropic Hardening material. Here are the simulation results.
March 20, 2021 at 2:36 pmpeteroznewman
SubscribernThis model is so small and easy to mesh, there is no need to use the Nonlinear Adaptive Region capability.nJust use a small element size for the domain. If you want smaller elements locally around the footing, place a coordinate system at the center of the footing and use a Body Sizing mesh control with Type: Sphere of Influence. Select the coordinate system and type in a Radius and Element Size.nViewing 1 reply thread- The topic ‘How and when to use the Nonlinear adaptive region?’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
