How can calculate a stress along centre line of single lap adhesive bonded joint of rectangular 3D s
March 15, 2021 at 7:02 am
pateldineshkuma
SubscriberI am working on ansys 17.2 apdl n -
March 19, 2021 at 6:20 pm
Sean Harvey
Ansys Employee,nTo do this interactively you can use the Path Operations in General Postproc. See image below. You will use the define path to set the path by nodes or location, then the Map onto path to set the quantity to the path, and finally use Plot path items to make contour or graph. The commands for these 3 main operations arenpathnpdefnplpathnLet us know if this helps. Thank younSeannn
Trending discussions
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
