How can fix errorsource design for Twin Builder is required to have transient-transient link enabled
March 9, 2021 at 12:43 pm
jrnithy
SubscriberMarch 9, 2021 at 9:07 pmJose Luis Gonzalez Hernandez
Ansys EmployeeHello,nCould you provide some background information on what type of simulation (or co-simulation) you are trying to run?nProbably some snapshots of your model. This will help in identifying potential sources of the error.nnThank younJose-LuisnMarch 10, 2021 at 11:52 amMarch 11, 2021 at 4:16 pmJose Luis Gonzalez Hernandez
Ansys EmployeeIt seems the Maxwell design being used is not the right type. Maxwell supports multi design types and settings.nYou need to enable and use a Transient-Transient Link and use a Maxwell design that supports that.nThank younJose-LuisnMarch 12, 2021 at 10:38 amjrnithy
SubscriberThanks. I done it but error 2 and 3 is persist again...nnI will try to resolve itnnthanks boss..nViewing 4 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1285
1104
459
