how can i add air exhauster to my project?
    • yarenaslii
      my project is about internal flows on a ceramic pipe. You can think of this pipe as a heat exchanger.
      1) By applying a fan to the entrance of the device, air flow should be provided due to the pressure difference.
      2) All analyzes will be made under Continuous Regime conditions.
      3) The fan will press the air at 28C at 20 kPa effective pressure at the device inlet to the environment at 20C at the outlet.
      4) Likewise, the fan will **** the air at the outlet at 20oC at -20 kPa effective pressure and pass it through the device.
      5) The temperature condition of the air passing through the ducts in suction and discharge conditions will be examined.
    • yarenaslii
      here is the heat recovery system. i need to add air exhauster to front size.
      You need to add the fluid region too: in CFD we generally want the bit where the metal isn't. You'll also need to include the metal part for heat transfer.
    • yarenaslii
      thank you i will try
Viewing 3 reply threads
