February 12, 2022 at 4:04 pm
AbhinavArun
SubscriberI wanted to know how to add adition coating on a sphere and what are the things that I need to take care of while simulating a SERS based biosensor
February 14, 2022 at 11:07 pmGuilin Sun
Ansys EmployeeLumerical uses mesh order to distinguish objects. So you can add a coating sphere with radius R1 on the base sphere R2, where R1 has lower mesh order than R2, or set the R2 mesh order higher than R1:
Please refer this post:
Ansys Insight: Simulating hollow or coated objects with mesh order
February 14, 2022 at 11:08 pmGuilin Sun
Due to some reason, the images may not display correctly on time, so it is duplicated.
Please note that this post topic is also duplicated. I was wondering what happened when I found this post not replied but I remembered replied already.
Trending discussions- Why am I getting “process exited without calling finalize”, and how do I fix it?
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5310
3311
2471
