February 14, 2022 at 5:32 am
AbhinavArun
SubscriberI wanted to know how to add an aditional coating on a sphere and what are the things that I need to take care of while simulating a SERS based biosensor
February 14, 2022 at 7:19 pmGuilin Sun
Ansys EmployeeLumerical uses "mesh order" to distinguish different geometries/materials. Therefore, you can add a coating sphere with radius R1 on the base sphere R2, where R1>R2, and choose the mesh order of the base sphere higher than R1, or choose R1's mesh order lower than R2. Please refer Understanding mesh order for overlapping objects
Please refer this example: Surface-enhanced Raman scattering I wrote a few tips there.
- Error on Lumerical device
3930
2649
1865
1272
610
