March 22, 2021 at 7:08 am
xiaoran
SubscriberMarch 23, 2021 at 4:00 amGuanhui Wang
Ansys EmployeeHi Xiaoran,nnYou can combine several step sources with the delay options in it to form this waveform. For example, in the first step source, set its delay = 1e-9s, bias = 0, amplitude = 1; then in the second step source, set its delay = 2e-9s, bias = 1, amplitude = 1, so on and so forth. Then use a SUM element to combine the sources together. nViewing 1 reply thread- You must be logged in to reply to this topic.
- Error on Lumerical device
2524
2066
1279
1096
457
