March 10, 2022 at 6:16 pm
gerardsoldevilla99
SubscriberHello everybody, I ask you for some help with something I don't really understand about my simulation results.
I am simulating a body that has a cylindrical shape with some circular round sections on the borders of the cylinder. Such as this I show you:
March 17, 2022 at 11:56 pmSurya Deb
Ansys EmployeeHello,
Please check the influence of reference pressure in the force calculations.
You can check the link below for more information
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/cfx_ref/i1308522.html?q=force_x
SD
March 18, 2022 at 9:40 amDrAmine
Ansys EmployeePressure Drag is done with Static Pressure / Absolute Pressure and not via Total Pressure!
March 29, 2022 at 11:45 amgerardsoldevilla99
SubscriberThanks, and sorry for the delay in the answer.
Something was not going right with Absolute Pressure either, the calculated force had the opposite sign as expected, but actually, I tried with the Static Pressure, although there is no such a variable with this exact name I tried with the Pressure variable, which I imagine is equivalent, in this way, the result matches perfectly with the expected result.
I will assume those results as valid.
March 29, 2022 at 11:47 amDrAmine
Ansys EmployeePressure is static gauge pressure. Opposite sign means for me that the direction is wrong.
March 29, 2022 at 11:50 amgerardsoldevilla99
SubscriberThank you, I can't access this file for some reason, do you have any other way to share me, with a screenshot or sth, by the way, my reference pressure is kind of fixed in my problem, I am simulation an airplane at cruise altitude of FL490, so I set the reference pressure as 20kPa, and I don't think there's a reliable way of doing that.
Could you share with me the document you talk about, thank you anyway
Viewing 5 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
457
