February 25, 2022 at 1:40 pm
Roya
SubscriberHello everyone,
I am trying to calculate the interfacial area for my aerated bioreactor. The bioreactor is filled with liquid up to H and the rest is filled with air (Figure below). There is air injected at the bottom of bioreactor in the form of single-size bubbles. I would like to calculate the interfacial area for the liquid phase (media-bubbles). I would like to know how I can calculate it?
February 25, 2022 at 1:59 pmRob
Ansys EmployeeHow are you injecting the bubbles?
February 25, 2022 at 2:03 pmRoya
SubscriberI inject the bubbles through the inlet which is at the bottom of the tank (the ring sparger). I use Eulerian multiphase model (dispersed) for modeling the flow.
February 25, 2022 at 2:08 pmRob
Ansys EmployeeOK. Currently you'll need to split the domain to have a separate fluid region in the liquid part and then get the bubble volume fraction in that zone. A UDF would work but you'll need to limit the region that it looks in to be below the free surface height. We have asked for some more tools, and they're in development.
February 25, 2022 at 2:34 pmRoya
SubscriberI don't know if I got what you mean, but if I understand you correctly:
I have already used a region_0 (Adapt/Patch) to specify the region at the top which is filled with air. Is that what you mean?
Even if I separate the fluid region from the air region, the surface doesn't remain unchanged as the fluid is being stirred and vortexes appear at the top surface.
February 25, 2022 at 4:18 pmRob
Ansys EmployeeSort of. We can also use those registers to split the cells into different zones. If you're getting vortexing that makes it a little more complicated as you'd need to adjust the split every time you wanted the data. may have another idea but I think you will need a UDF and limit the data gathering to below the free surface.
March 1, 2022 at 1:01 pmRoya
SubscriberDear Rob,
How can I simply write a UDF and define interfacial area as a parameter that I want to be calculated, But ask the code to only calculate it where volume fraction of air is less than one (which is where the liquid phase exists)?
I don't think DEFINE_EXCHANGE_PARAMETERS really work here as it takes the UDF to the phase interaction tab which is not what I need. I am not activating any mass transfer model, so basically using interfacial area option in phase interactions tab is meaningless for me.
Do you think that it would solve the problem or would it cause issues and is inaccurate?
Kind regards Roya
March 1, 2022 at 1:29 pmRob
Ansys EmployeeIt'll be one of the volume of fluid macros, use https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_udf/flu_udf_sec_define_mass_transfer.html as a starting point. You're not changing phase, but do want to dump the data to a UDM.
The problem you'll face is distinguishing the volume fraction caused by bubbles and the region around the interface.
March 1, 2022 at 2:40 pmRoya
SubscriberDear ROB Is there any UDF in Fluent in which can calculate the volume fraction of one phase in another phase? Then I can use the DEFINE_REPORT_DEFINITION_FN and calculate the interfacial area in a second UDF.
Regards Roya
March 1, 2022 at 3:25 pmRob
Ansys EmployeeIsn't C_VOF the volume fraction?
March 1, 2022 at 4:30 pmRoya
SubscriberYes, it is. But it only gets the value of volume fraction correctly if it is specified for the volume fraction in one phase. In my case, I have a region at the top which is filled with air. And I don't want that section to be involved in the calculation. I want the volume fraction of air only in liquid phase. Is that also still under develop in ANSYS? Or is there any UDF available for that?
March 1, 2022 at 4:34 pmRob
Ansys EmployeeThat's the volume fraction, whether it's in the air (only) or a fraction in the liquid it's still the same macro.
Viewing 11 reply threads- You must be logged in to reply to this topic.
2688
2138
1355
1136
462
