Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
How can I calculate the magnetic flux density in each element?
    • ralmazmomi
      Hello, nI want to get the flux density in each element in the iron core mesh and sum them all. I tried to use field calculator, but there is no option for that. I just can take the average for the flux density over the core. nI just want to do summation in the whole core.n
    • Navya C
      nyou can export the magnetic flux density at each mesh element utilizing the fields calculator as belownGo to Maxwell 2D/3D > Fields > Calculator and use the following commands:nInput > Quantity > B, Input > Geometry > Volume > Rotor (for example select any geometry) General > Domain Output > Write > input a file name you want to and save.nThe outcome will be a file with all the elements in the rotor and the vector field values in each node of the element.nnRegardsnNavyan
    • ralmazmomi
      nI got the file with an extension of .fld. nhow can I extract the results? nThank you n
    • Navya C
      nI think you can open that file with notepad.n
Viewing 3 reply threads
