March 16, 2021 at 11:45 am
abd fs
SubscriberDear researchers, I am simulating an unsteady turbulent flow (ideal gas) in complex geometry, and I want to calculate the Reynolds number of the flow. At the entrance of the field, a pressure of 0.25MPa, is imposed. My question is: how can I calculate the Reynolds number of the flow inside computer domain?
Best regards,
SERRAR
March 16, 2021 at 12:34 pmRob
Ansys EmployeeTreat the solver result in exactly the same way you would experimental data. How would you do the calculation there?
March 16, 2021 at 3:57 pmabd fs
SubscriberDear Rob I have no experimental data, I only have the results digitally simulated by Fluent.
If possible, do you have any recommendations for finding the Reynolds number?
Best regardsMarch 16, 2021 at 5:04 pmRob
Ansys EmployeeWhich are a simulation of a real system. In the real system how would you calculate Reynolds Number?
March 16, 2021 at 6:30 pmabd fs
SubscriberDear Rob Thank you very much for your quick responses. I want to share with you my domain of computation to give you a vision of what I'm talking about.
Best regardsMarch 17, 2021 at 4:43 pmRob
Ansys EmployeeStaff are not permitted to open or download attachments.
March 17, 2021 at 5:49 pmabd fs
SubscriberDear Rob Since you can't open the image, you can just type sweeping jet on google and you will find what I have researched.
Thank you so much for your help Best regards SERRAR
March 18, 2021 at 2:55 amMarch 18, 2021 at 9:02 amabd fs
SubscriberDear Yasser
Do you have any idea how can I calculate the number of Reynolds?
Best regards SERRAR
March 18, 2021 at 1:13 pmYasserSelima
SubscriberRe number is used for comparison between similar cases at different scale and flow conditions. So, I would look in the literature for similar case .. if nothing is found, I would calculate it at the entrance
March 18, 2021 at 1:19 pmabd fs
SubscriberThank you so much for your help, Mr Yasser
March 18, 2021 at 1:47 pmYasserSelima
SubscriberYou are welcome!
March 18, 2021 at 2:22 pmRob
Ansys EmployeeAh, a bi-stable fluidic oscillator. Make sure your mesh is VERY good.
March 18, 2021 at 2:54 pmabd fs
SubscriberDear Rob Since I have a complex domain, I have divided it into several subdomains, which increases the quality of the network.
Beste regards SERRAR
Viewing 13 reply threads- You must be logged in to reply to this topic.
2564
2080
1293
1106
459
