March 10, 2021 at 7:48 am
Sherin
SubscriberI would like to calculate self inductance and mutual inductance of the transformer wingdings of my design.
I can see these terms in the result window, but didn't have any value.
What are data I need to enter for obtaining these value in the result window.
Didn't find any matrix entry in Parameters similar to magneto-statics.
March 10, 2021 at 11:39 amNavya C
Ansys EmployeeHi @Sherin nHave you checked the below option?nGo to Maxwell2D/3D>Design Settings nUnder the Matrix Computation tab check the Compute Inductance Matrix and select Apparent to let Maxwell calculate the apparent inductance for you.nRegardsnNavyan
March 12, 2021 at 4:25 amSherin
SubscriberThank you very much.nnApril 15, 2021 at 10:33 amisaichaitanya
SubscriberI have tried it but still problem persists ......is there any other solutionnViewing 3 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
