March 10, 2021 at 10:02 am
ma560
SubscriberI have ansys edt 2020 and I was wondering if I can change the solution type.n -
March 10, 2021 at 12:42 pm
Navya C
Ansys EmployeeHi @ma560nWhich solution type are you using in Maxwell?nIterative solvers are supported in 3D- magnetostatic, electrostatic solvers, and eddy current solvers.nTo enable the iterative solver:n1. On the Solution Setup dialog box Solver tab, check the Enable Iterative Solve check box. This enables the Relative Residual input field.n2. Enter a value for the Relative Residual. The residual measures the convergence of the iterative solver. The default value is 1e-6 for the magnetostatic and electrostatic solvers and 1e-4 for the eddy current solver.nRefer to the Maxwell help section for more details.nnRegards,nNavyan -
March 10, 2021 at 5:23 pm
ma560
SubscriberHi @ma560Which solution type are you using in Maxwell?Iterative solvers are supported in 3D- magnetostatic, electrostatic solvers, and eddy current solvers.To enable the iterative solver:1. On the Solution Setup dialog box Solver tab, check the Enable Iterative Solve check box. This enables the Relative Residual input field.2. Enter a value for the Relative Residual. The residual measures the convergence of the iterative solver. The default value is 1e-6 for the magnetostatic and electrostatic solvers and 1e-4 for the eddy current solver.Refer to the Maxwell help section for more details.Regards,Navyahttps://forum.ansys.com/discussion/comment/110196#Comment_110196
HinI was wondering if I can use a direct solver (I'm using maxwell 2D and 3D depending on the problem in hand)n -
March 10, 2021 at 5:27 pm
ma560
SubscriberAnd I'm using electrostatic solversnhttps://forum.ansys.com/discussion/comment/110196#Comment_110196HiI was wondering if I can use a direct solver (I'm using maxwell 2D and 3D depending on the problem in hand)https://forum.ansys.com/discussion/comment/110240#Comment_110240
n
- Maxwell, HFSS or Q3D?
- Error
2532
2066
1285
1104
459
