May 29, 2018 at 1:14 pm
a.cinciripini
SubscriberHello Everybody,
I am facing a small issue in Results task in Ansys AIM.
Basically when I calculate a value, like mass flow at outlet for instance, I don't find the way to change the system units. I would like to show this number in (m^3/h). This happens both with "function calculation" and with "user defined expressions". If I change the units under Units>Unit system, it works only if I use the predefined settings (like SI, U.S.Eng.....), but does not work if I use custom units, so setting "hours" as time unit.
Thank you in advance for your support,
Bye bye,
Alessandro
May 29, 2018 at 9:25 pm
Brian Bueno
Ansys Employeealecinci
This may be a limitation at the current point in time. I will have to ask the development team if there is any way around this.
May 30, 2018 at 2:49 pm
May 30, 2018 at 3:38 pm
a.cinciripini
SubscriberThanks so much for your reply.
I see.... this seems working in this case for a time dependent analysis to visualize the time-step advancement.
Unfortunately using the same method (so creating a custom unit system) I saw it does not work for time based units system, like volume flow rate in m^3/h instead of m^3/s.
I will wait for the development team answer....
Thanks a lot again
Alessandro
- loss of user settings
- Ansys Discovery Modeler vs Spaceclaim speed
- pressure
- Annotation font color
- Can’t see license on online account
- Copy user settings to new release
- help online
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Unexpected graphics error
- Python Script: graphical interface
5268
3299
2469
