How can I compute the heat conduction in a solid body? What equation or formula should I use?
    • Karthik R
      Administrator
    • prajput
      You can compute it using Fourier's law. It states that the rate of heat transfer through conduction is directly proportional to the thermal gradient (dT/dx). Mathematically,
      q_x = - k * A * dT / dx (1D conduction)
      where,
      q_x - rate of heat transfer in x direction
      k - thermal conductivity of the material
      A - area normal to the direction of heat transfer
      dT / dx - thermal gradient
      The minus sign is necessary because heat is transferred in the direction of decreasing temperature.
    • Karthik R
      Administrator
      Thanks @pankajhr , So what is the physical meaning of the thermal conductivity in the Fourier's conduction equation?
    • prajput
      Thermal conductivity is a transport property which indicates the rate at which energy is transferred through conduction. Efficient conductors have a high thermal conductivity. Materials with poor thermal conductivity are referred to as insulators.
    • Karthik R
      Administrator
      Thanks
Viewing 4 reply threads
