September 9, 2019 at 6:58 am
Doba
This is a cylinder with a perforated plate in the middle. The surface "Wall" is the surface where I added the No Slip condition. Now I want to see the y+ values at this Wall surface BUT without the cylinders on the left and right side of the plate. Is there any way to cut the surface? Like how you can when you do the section analysis in the meshing application.
This is how the plate looks -
September 9, 2019 at 12:09 pm
Ansys EmployeeThere are a few options, have a look at iso surfaces and clip options. If you'd labelled the walls in Meshing then you can also display each section by label: it's always good practice to label for post processing.
2656
2120
1347
1118
461
