TAGGED: earthquake, i, interlocking, structural-analysis
February 11, 2022 at 6:39 am
AaronPaulM
SubscriberI'm a 10th Grade Student working on a research paper regarding interlocking blocks. We aim to design a block that can be effective against earthquakes. We would want to know how can we design IHBs and test a wall made out of them against earthquakes? Is it possible?
February 13, 2022 at 2:10 pmpeteroznewman
SubscriberHello Aaron This sounds like an interesting project.
ANSYS has several pieces of software that can help with this project. Start by learning to create solid models of the block using SpaceClaim.
There are lots more videos you can find on YouTube.
Once you have a block designed, there are several ways to simulate how stable the design is against earthquakes.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7592
4440
2953
1427
1322
