October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeYou can do two separate modal (each with less than 10,000 modes) and two separate spectrum analyses based on the modal analyses and then SRSS combine the results. To capture the full modal range, you need to request 10,000 or fewer modes in the first modal analysis and specify the end frequency (FREQE) from the first modal analysis as the beginning frequency (FREQB) for the second modal analysis. You then need to do two separate response spectrum analyses based on the two separate modal results. After each spectrum analysis, you can use RAPPND to write the results to an rst file. Finally, you can use a load case combination to SRSS the results from the two response spectrum analysis to calculate the combined result for the full modal range. You can use the FILE command to toggle between the two spectrum rst files within /POST1.
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- What is cause of error: display time for result item greater than the step end time?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
Top Contributors
2616
2098
1321
1108
461
Top Rated Tags
