how can i draw chart bt. ( area weighted average temperature of certain surface Vs time )
    • AGAAMAZ
      Hello everyoneni have a glass surface of variant temp. while time passesnhow can i draw chart bt. ( area weighted average temperature of this surface Vs time ) ?n
    • Karthik R
      Administrator
      Hello,nPlease create a monitor in Fluent, please check here: Solution -> Reports -> Definition -> Surface Report -. Area-Weighted-AveragenTo create a plot with time, your simulation needs to be transient. Fluent will Automatically create this report as a function of Flow Time.nKarthikn
    • AGAAMAZ
      nthank you sir , i did it but if i close ANSYS the reopend the project again how can i see it again , and can i see it in cfd-post ?nn
    • Karthik R
      Administrator
      Hi,nYou will want to use the 'Report File' option when you create this monitor. This will write the values as a file. You can then re-open the file whenever you open the Fluent case and data. nTo create a plot from the written file, you need to use Plot -> Data Sources -> Point to the correct source (file) and replot.nKarthikn
Viewing 3 reply threads
